1 odd face error
robert827
PostPosted: Tue Apr 07, 2009 9:54 pm    Post subject: 1 odd face error Reply with quote
every time i go to load my character in UVlayout it comes up with this 1 odd face error, i have no idea what this means... :/
how can i fix it?
PostPosted: Tue Apr 07, 2009 10:44 pm    Post subject: Reply with quote
UVLayout does a topology check when loading the mesh. Usually the "odd faces" error is caused by non-manifold edges, where more than 2 faces share a side.
Ticking "Clean" in the load options window will usually fix these.
robert827
PostPosted: Wed Apr 08, 2009 6:06 pm    Post subject: Reply with quote
thats the problem, without clean theres 70 odd faces...with clean theres just 1, does that mean that somewhere theres 2 polygons that share a face?
PostPosted: Wed Apr 08, 2009 6:19 pm    Post subject: Reply with quote
Hmmm, what you could try is to load it with Clean on, then save it out right away as a new OBJ, then re-load the new OBJ.
Which version are you using? Occasionally I update the Clean function, so you may need to upgrade to fix the problem.
robert827
PostPosted: Wed Apr 08, 2009 6:23 pm    Post subject: Reply with quote
all i can see is it says v2, is there a way to be more specific?
PostPosted: Wed Apr 08, 2009 6:46 pm    Post subject: Reply with quote
Click on the blue "About UVLayout" button at the top of the main GUI window.
robert827
PostPosted: Wed Apr 08, 2009 7:31 pm    Post subject: Reply with quote
v2.00.07 is what im using, i think i found the problem, but im not sure yet, attempting to fix it.
PostPosted: Wed Apr 08, 2009 7:34 pm    Post subject: Reply with quote
That version is over a year old now ... a lot has been improved in the Clean function since then.
robert827
PostPosted: Wed Apr 08, 2009 7:38 pm    Post subject: Reply with quote
ah damn, can i update from the site?
PostPosted: Wed Apr 08, 2009 7:52 pm    Post subject: Reply with quote
Login to your uvlayout.com account and you'll find the latest version on the Support Download page.
If its been over a year since you purchased your license then more than likely you'll need to update your support subscription before you can download; its $50 a year, and you can pay that from your Support Details page.
robert827
PostPosted: Wed Apr 08, 2009 8:10 pm    Post subject: Reply with quote
ok thanks, i quickly tried out the trial. works like a charm! props on the great timesaving program Smile
