ld-linux.so.2 error on fedora 10 x64
mattrm
PostPosted: Sat Jan 24, 2009 2:09 am    Post subject: ld-linux.so.2 error on fedora 10 x64 Reply with quote
I have this error :
Quote:
bash: /home/mattRM/uvlayout-pro/bin/uvlayout: /lib/ld-linux.so.2: bad ELF interpreter: no file or directory
I don't know why I had this error because under ubuntu x64 it was work...
Somebody had an answer ?
Thanks
ps : export paths and libs variables are in .bashrc
Matt
PostPosted: Sun Jan 25, 2009 8:57 pm    Post subject: Reply with quote
It so happens I have a brand new fc10 64bit laptop here that I'm still in the process of setting up.
Anyway, when I try and run the uvlayout installs (rh9 or fc6) I get a "command not found" error. Very odd, but could also be because of a missing backwards compatible libc or something. I'll do some more investigating tomorrow.
I did also check a fc8 64bit build I made not too long ago, but not available from uvlayout.com site currently. It worked fine, so if I cant get the other builds to run, I can make the fc8 build available.
PostPosted: Sun Feb 01, 2009 11:08 pm    Post subject: Reply with quote
I worked out how to fix my own fedora 10 64bit "command not found" error; its because I didn't have any 32bit shared libs installed. Running the following command loaded what was required, so it might be worth try that too.
Code:
yum install glibc.i686 libSM.i386 libX11.i386 libXpm.i386 \
  libXp.i386 libXmu.i386 libXi.i386 libXft.i386 mesa-libGLU.i386 \
  mesa-libGLw.i386 libjpeg.i386 libtiff.i386
These font were required too ...
Code:
yum install xorg-x11-fonts-75dpi.noarch xorg-x11-fonts-ISO8859-1-75dpi.noarch
