Rotate problem!
ImaginationTao
PostPosted: Wed Jan 28, 2009 6:38 am    Post subject: Rotate problem! Reply with quote
Working on my own obj models, the rotate(left-click) is weird that I cannot rotate to observe all viewpoints-have a feel that its blocked, stopping rotate.
There is no the problem if I open UVLayout and work on the default torus.
Thanks for the solution.
PostPosted: Wed Jan 28, 2009 7:38 pm    Post subject: Re: Rotate problem! Reply with quote
" the rotate(left-click) is weird that I cannot rotate to observe all viewpoints-have a feel that its blocked, stopping rotate."
Yes, by default its locked so that the Y-axis is always up. Under the Display panel you'll see four choices for "Up" ... the "Free" one will let you tumble the object around without any restrictions.
ImaginationTao
PostPosted: Thu Jan 29, 2009 8:52 am    Post subject: Reply with quote
Thanks very much!
