Ju_
Posted: Wed Nov 12, 2008 7:42 am Post subject: UVLayout crashing after updating NVidia graphics drivers |
I just installed the latest drivers for my NVidia 8800 GTX graphics card. Ever since, UVLayout crashes upon loading any file. It doesn't come up with an error message but with the windows crash dialogue that asks if I want to send an error report.
Before I installed the new drivers it worked absolutely fine. I also tried rolling back drivers and it's working again, but unfortunately I need the latest drivers for Maya.
This is the driver causing problems:
GeForce Release 178 WHQL
Version: 178.24
Operating System: Windows XP x64, Server 2003 x64
Any ideas or suggestions?
Thanks for any help!
Julia |
Posted: Wed Nov 12, 2008 2:54 pm Post subject: |
Are you running a Dualview system? I have heard of problems before in older nvidia drivers, but couldn't ever replicate that particular problem here with up to date ones.
Another user reported recently that if they disabled thread optimization in the nvidia driver options, that would cause a UVLayout crash also when files are opened. Actually, he was doing that to get Maya working, so I'm wondering if you've done that as well?
Anyway, I'll have a play here today sometime ... see if I can get any of my nvidia systems to crash when I change settings, and then I'll hopefully be able to find a work-around.
Ju_
Posted: Thu Nov 13, 2008 2:48 am Post subject: |
Yes that was it exactly, I did disable thread optimization. I just turned it back on to check and UVLayout is working fine now. So that's a workaround, thanks a lot.
Would you know if there is a way to fix this though? We work in Maya a lot so unfortunately need thread optimization to be turned on.
And although it's a workaround it would save our team a lot of time if we didn't have to change driver settings every time we switch between Maya and UVLayout...
Thanks again for your quick reply!
Julia |
Posted: Fri Nov 14, 2008 12:34 am Post subject: |
" I did disable thread optimization. I just turned it back on to check and UVLayout is working fine now."
"We work in Maya a lot so unfortunately need thread optimization to be turned on. "
Did you really mean "off" in that last sentence?
Anyway, its good news at least that you have a work-around, and there's two people now with the exact same problem, so I'm hoping I'll be able to get it to go wrong here too. I unfortunately didn't get around to it today, but will have a look first thing next week.
Posted: Fri Nov 14, 2008 6:59 pm Post subject: |
I've hit a hurdle ... the most modern nvidia card we have here is on a Vista laptop, and official drivers are released about once every ice age, so I cant get UVLayout to crash here with Threaded Optimization on or off using the current (old) driver.
See attached image ... what you should be able to do is add an exception for uvlayout so the driver handles the threaded optimization thing differently to your global setting. What you need to do is click on the "Add" then browse for the cyeatP.exe file in the UVLayout install folder, then change the threaded optimization setting in the panel below. I don't know if it'll work, but is worth a try.
paqwak
Posted: Sat Nov 15, 2008 1:39 am Post subject: |
Thanks for tip, that's exaclty what I did, except that I have created the 'special' profile for maya, because so far it's the only software that give me problem when thread optimization is ON.
So to resume:
- Thread opimization ON by default
- Thread opimization OFF for maya
Works fine for me (Nvidia 9600GT) |
Posted: Sat Nov 15, 2008 1:46 am Post subject: |
Excellent! Thanks for the update, and fingers crossed its also going to work for Ju_.
