exporting to maya!! its driving me insane
jaston1984
PostPosted: Thu Aug 21, 2008 3:26 pm    Post subject: exporting to maya!! its driving me insane Reply with quote
this is my first time laying out uvs so bare with me!
i have created this brilliant layout all neatly done but now im stuck. i save the file as an obj but when i load/import the file back in maya its blank! im not sure what i am supposed to be seeing! when i update instead of save i get the same results.there isnt anything in the uv layout editor either so i thought i would load the file into z brush which seemed to work but then i did a uv check and half the model was still rubbish! but yet the uvs are great in uvlayout editor! please help
PostPosted: Thu Aug 21, 2008 4:42 pm    Post subject: Reply with quote
Yikes, that sounds bad! It definitely sounds like a bug, but not one I've seen before.
Can you email me the object in question? Three files would be good ... the OBJ before it goes into UVLayout, a UVL file of your perfect layout, and the OBJ exported by UVLayout. If I can see the files myself I should be able to come up with a fix or answer quite quickly.
NightGamerFX
PostPosted: Mon Apr 19, 2010 9:58 pm    Post subject: Reply with quote
I have the same exact problem except I'm using 3ds MAX 2010.
Again everything is how I want it to be in UVL but I don't see Unwrap UVW in the modifiers panel. its just my models unwrapped.
Need help ASAP much thanks.
-NGFX
View user's profile Send private message Send e-mail
PostPosted: Mon Apr 19, 2010 10:03 pm    Post subject: Reply with quote
Are you using the UVLayout to Max plugin? If not, I'd recommend having a look at it ...
http://www.headus.com/phpbb/viewtopic.php?t=402
It simplifies the transfer of meshes between UVLayout and Max, and may solve the problem you're having.
