UVLayout v2.02 now available
PostPosted: Tue Jul 08, 2008 11:38 pm    Post subject: UVLayout v2.02 now available Reply with quote
Hello All,
UVLayout v2.02 is now available for Professional users from ...
New features added in this version:
- Reshape: With this tool you can copy UVs between morph targets. It differs from the normal Copy UVs tool because reshaping gives you the option to calculate a 50/50 blend between the morph target shapes, which you can then reflatten to balance the texture distortion across the two meshes. A video showing this in action can be found under the Advanced videos at www.uvlayout.com/videos
Changes to existing features:
- Load Clean option : now also welds co-incident geometry vertexes.
tantarus
PostPosted: Wed Jul 09, 2008 10:49 pm    Post subject: Reply with quote
Fantastic updates, Clean now work like a charm. Will sure help with messy geom. Smile
Tihomir
PostPosted: Wed Jul 23, 2008 1:13 am    Post subject: UVLayout v2.02.01 now available Reply with quote
Hello All,
UVLayout v2.02.01 is now available for all users from ...
Bugs fixed:
- Rolling the wheel mouse over the main GUI window caused a
fatal error under Windows.
PostPosted: Fri Aug 08, 2008 12:33 am    Post subject: UVLayout v2.02.02 now available Reply with quote
Hello All,
UVLayout v2.02.02 is now available for Professional users from ...
- Home folder preference : If drag'n'drop isn't used to start
UVLayout, then this setting determines which directory is opened
when the Load or Save buttons are first used.
- Desktop icon action : When the UVLayout desktop icon is double
clicked, UVLayout itself will now run. The licensing GUI will
only appear if no valid key is found.
- Slow Smooth Optimize preference : By default this is on, and
it means that when the Optimize is run, shells are redrawn at
every flattening optimization step. By turning this off, the
optimize will only redraw shells twice a second; even though
it looks slower, the CPU is now spending more time flattening,
and so it'll get to the optimal result quicker.
PostPosted: Wed Aug 13, 2008 10:15 pm    Post subject: UVLayout v2.02.03 now available Reply with quote
Hello All,
UVLayout v2.02.03 is now available for Professional users from ...
Bugs fixed:
- The addition of the Home folder preference in v2.02.02 broke the Maya plugin.
