Import UVs
redspark
PostPosted: Tue Apr 01, 2008 3:32 am    Post subject: Import UVs Reply with quote
Is there a way to import UVs from another OBJ file or an exported file? Thanks.
James
PostPosted: Tue Apr 01, 2008 4:00 am    Post subject: Reply with quote
The last major release (v2.01) added the Copy UVs tool; it allows you to copy UVs between objects with the same topology. Currently you have to have both objects in the same OBJ file, so you'll need to use some other application (eg maya or 3ds) to gather your various objects into the one OBJ file if they aren't already.
Is that what you meant by "import" UVs?
