Texture Issue
MayaMike
PostPosted: Sat Mar 08, 2008 9:34 am    Post subject: Texture Issue Reply with quote
I've seemed to have lost the green/red/blue texture when cycling through the textures. I have the numbers and grid only. I must of hit a wrong key because now its not showing, instead its all grey.
Mike
Lewi
PostPosted: Sat Mar 08, 2008 12:24 pm    Post subject: Reply with quote
Sounds like you have changed your display mode. If you go to the " Display " tab and then the " Color " settings and choose " Error " this should fix it.
MayaMike
PostPosted: Sat Mar 08, 2008 12:38 pm    Post subject: Reply with quote
Thanks a bunch Lewi, your suggestion fixed it.
Mike
