UVLayout under ubuntu
ilbozo
PostPosted: Sat Mar 08, 2008 12:55 pm    Post subject: UVLayout under ubuntu Reply with quote
I'm trying to use UVLayout on a Ubuntu 7.10 Gutsy. I translated the instructions from your site (fedora to ubuntu) and when i try to launch UvLayout from the program shell i get this error message:
Code:
cysliceD: error while loading shared libraries: libXm.so.4: cannot open shared object file: No such file or directory
Is it because of some dependecy? Please help me, i'm using uvlayout in wine...
PostPosted: Sat Mar 08, 2008 5:25 pm    Post subject: Reply with quote
I've included the required shared libs in the linux installation, under the "lib" directory; they're not used by default in case theres a conflict with existing libs in the system. But if yours are missing, try using the supplied ones by setting LD_LIBRARY_PATH ...
setenv LD_LIBRARY_PATH $HEADUS_HOME/lib
