Question regarding moving pieces in UV view
channing
PostPosted: Fri Jan 18, 2008 7:38 pm    Post subject: Question regarding moving pieces in UV view Reply with quote
I'm having trouble doing any moving of pieces dropped into UV space other than rotating them on an axis point. I've watched the videos and it appears that the space bar and the middle mouse button are used to move the pieces. I have a mouse that has a left and right button, and a scroll wheel in the center.
Am I misunderstanding something or is there a workaround.
By the way, I really like the program a lot. I think it will be coming out of my next paycheck. Smile
isaac_cm
PostPosted: Sat Jan 19, 2008 10:36 am    Post subject: Reply with quote
Move: press on the while itself+space bar
Rotate: left button+space bar
channing
PostPosted: Sat Jan 19, 2008 2:08 pm    Post subject: Reply with quote
I'm a little confused ... what do you mean by "press on the while itself" part of the Move command? Thanks for the reply though.
PostPosted: Sat Jan 19, 2008 4:59 pm    Post subject: Reply with quote
I think isaac_cm meant "press on the wheel itself". You could try that because often its a wheel and a button.
Or open up the Preferences panel and select the "2" mouse buttons option and restart UVLayout. You'll then be able to use the right button to move shells about, as if it was the middle, but you'll have to use LMB+RMB now to zoom the view.
channing
PostPosted: Sat Jan 19, 2008 5:25 pm    Post subject: Reply with quote
It works perfectly. Thank you. All I need is to get used to the key combinations and watch the videos. This is a great program. I dread UV mapping, and this will make it much easier for me.
