flattern problem
CoreX
PostPosted: Tue Jan 15, 2008 11:59 am    Post subject: flattern problem Reply with quote
I had a symmetrical mesh. After flattern(optimize) i got an asymetrical mesh. In the pic you can see the result. What could be the problem? Did i make a mistake?? What i can do now?
THX
Andreseloy
PostPosted: Tue Jan 15, 2008 4:32 pm    Post subject: Reply with quote
press again simmetry find and press enter then each time you work in half mesh press s to restore simmetry.
Andreseloy
PostPosted: Tue Jan 15, 2008 4:48 pm    Post subject: Reply with quote
In the Hobbyist/Student versions you can use the Symm tool under the Stack panel to make the boundary symmetrical, then re-flattening should make the internals symmetrical as well if the 3D mesh is. This is covered in the Old Beta v1.11.1 movie.
In the Professional version you can use the Symmetry Find tool to make the whole shell symmetrical about a selected edge. This is covered in the Advanced Symmetry-Find movies. You can also use the Stack Symm method in the Pro version too.
Unfortunately there's not much you can do about it in the Demo version, other than to load it into the Pro version trial, but then of course you cant save the result out.
