Losing Materials and Grouping
Predatron
PostPosted: Thu Nov 29, 2007 11:04 am    Post subject: Losing Materials and Grouping Reply with quote
I've been working on an obj for a little while and have been using the update feature on a number of occasions to save my work. This has up until now saved all my material zones and groups. Then all of a sudden when I use update these are now lost and it reverts to one default group and no material zones are visible when viewing this in UVMapper Pro. I have tried deleting the updated version and starting again with the original obj, but this is still happening.
Do you know why this is?
PostPosted: Thu Nov 29, 2007 4:03 pm    Post subject: Reply with quote
"Do you know why this is?"
The Update will sometimes fail if the Clean load option was used. Also, if you are running a version older than v1.20.2, any polygon with more than 7 sides will be triangulated when loaded into UVLayout, and that'll break the Update. Since v1.20.2, this limit has been increased to 255 sides. UVLayout should pop up a warning when the file is loaded if any of these cases apply though.
It could also be a bug; if you don't mind me seeing your OBJ, email it over and I'll have a look.
Predatron
PostPosted: Fri Nov 30, 2007 4:11 pm    Post subject: Reply with quote
Thanks Phil for replying.
For the moment I manually reassigned the materials and groups as I was needing to get this finished. I did install the latest version though and there was no polygons with more than 4 sides.
If I can this error again I'll let you know though.
Another problem I did come across, but not on this particular OBJ is sometimes I have applied UV's in Max and if these are flat planar and some of the polys are laying stacked over each other they sometimes don't load into UVlayout and I get holes appearing in the mesh. I would then have to reapply the UV's using a different setting such as cylindrical and then import into UVlayout, is this a problem you have come across?
Cheers
Steve
PostPosted: Sun Dec 09, 2007 8:28 pm    Post subject: Reply with quote
" is this a problem you have come across?"
Not myself, but I mostly load things into UVLayout with New selected.
Send me an example next time you come across the problem and I'll have a look at it.
