Voluptuos Female Wip
Goto page 1, 2  Next
highlander_72
PostPosted: Mon Nov 05, 2007 11:20 am    Post subject: Voluptuos Female Wip Reply with quote
Hi guys,
I have another layout for a CGTalk modeling challenge and for you to critique here and would really appreciate any comments on how to further improve it.
Took me about 3 hours. According to your experience, is that fast or slow in regards to using Layout, I mean?
Cheers!
PS: I am probably sounding like broken record, but really have to say it again and again. Using UVLayout this work was actually fun! Very Happy
PostPosted: Mon Nov 05, 2007 6:52 pm    Post subject: Reply with quote
As always your pics are really interesting! Your seams look good to me ... nicely tucked away.
"Took me about 3 hours ... is that fast or slow ..."
There's a lot of detail in that mesh with individual finger and toes and a detailed face, so 3 hours sounds pretty quick to me.
highlander_72
PostPosted: Tue Nov 06, 2007 12:18 am    Post subject: Reply with quote
Thanks for the comments, Phil!
You are probably sick of hearing it, but I really couldnt have done it this way and as quick without UVLayout. It really was a breeze. The more I use it the more addicted to it I become.
You must have a deal with the dark side on this. lol Wink
Cheers!
PS: One thing I havent been able to fully understand though is this: Why does the color coding show me heavy stretch or compression in some places, which doesnt really show as distortion once a texture is projected onto the mesh, while when I manually "pull the areas into the green", a lot of weird texture distortion appears?
PostPosted: Tue Nov 06, 2007 12:55 am    Post subject: Reply with quote
The color coding is purely based on the relative areas of the polys, so for example, the applied grid for a red poly will appear stretched out compared to surrounding polys. There's currently no feedback for skewing type distortion (ie grid not square when applied).
UVLayout tries to make everything square at the expense of some stretching or compression. By hand manipulating the UVs to get polys green (ie correct area), you're probably introducing some skewing, and often thats going to end up looking worse.
Of course there's always going to be situations were you might need to hand tweak UVs, but I'd say in most cases that usually you're better off adjusting seam locations to get rid of read and blue areas.
Oh, and don't get too hung up on having an all green mesh either. A bit of stretching or compression in your texture might be a lot better than seams everywhere.
I'm just the programmer though ... professional texture artists would have their own opinions :-)
highlander_72
PostPosted: Tue Nov 06, 2007 2:43 am    Post subject: Reply with quote
Aha, I see! Many thanks for the explanation.
The skewing type distortion is exactely what I am getting with manual adjustment, so I basically just let Layout do most of the work on easy smaller island chunks, which I then weld to a larger piece according to the proper placement of seams. That usually produces a quite colorful overall mesh, but seems to be fine with a pattern applied.
Thanks again for the detailed input. Its greatly appreciated. Very Happy
highlander_72
PostPosted: Mon Nov 19, 2007 5:06 am    Post subject: Reply with quote
Hey Phil,
since you asked for it the last time. I'll harrass you with some, so far final renders for this particular challenge. Wink
[img]
The whole project is still far from finished and missing textures, particle/fluid/hair-fx and a background, but this is what I have right now and what is entered in the CGTalk HMC 11 voting thread.
Cheers!
[/img]
PostPosted: Tue Nov 20, 2007 12:30 am    Post subject: Reply with quote
Thanks again for the pics!
anrshelt
PostPosted: Wed Dec 26, 2007 5:10 pm    Post subject: Nice layout... Reply with quote
Nice layout....But I actually think that the UVs for the face should cover a much
larger area, or another UV range itself...
The devil is in the details...
ARS ii
highlander_72
PostPosted: Sat Jan 26, 2008 5:26 am    Post subject: Re: Nice layout... Reply with quote
Yeah, I agree. I'll probably fix that some time down the road.
Thanks for the comment!
Cheers!
UVDan
PostPosted: Sun Jan 11, 2009 7:50 pm    Post subject: Reply with quote
Fantastic job. Your powers are nothing to be sneezed at.
DRAKELOT
PostPosted: Mon Mar 23, 2009 9:09 am    Post subject: Reply with quote
Fantastic unfolding
highlander_72
PostPosted: Mon Apr 13, 2009 11:04 pm    Post subject: Reply with quote
Thanks a lot, guys! Smile
cali3d
PostPosted: Mon May 11, 2009 12:47 am    Post subject: Reply with quote
This is really good stuff !
View user's profile Send private message MSN Messenger
Kesha32
PostPosted: Mon Aug 30, 2010 10:40 pm    Post subject: Reply with quote
Hi!
I have nothing to say about that post.
Co'z it is very interesting...
Thank for sharing..........
make money online
SLI_Fallen
PostPosted: Tue Aug 31, 2010 4:34 am    Post subject: Reply with quote
"This image has violated our terms of use" -Photobucket.
oops. No pics now......
Goto page 1, 2  Next
Page 1 of 2
