My most complex organic mesh in UVLayout so far: Dragon WIP
highlander_72
PostPosted: Tue Oct 02, 2007 12:04 pm    Post subject: My most complex organic mesh in UVLayout so far: Dragon WIP Reply with quote
Hi guys,
I thought I'd show you my current wip and most complex organic mesh I have layed out in Phil's little masterpiece of a program so far. Considering the complexity of the mesh, UVLayout made it a breeze. Props for that go to Phil!
But enough talk, here's the base mesh in Maya:
The layed-out mesh with a checker texture applied:
and the layout in 0-1 space:
Let me know what you think, there's always room for improvement!
Cheers!
PS: The symmetry mode and the way it works is a true blessing! Many thanks again for adding that to the program, Phil!
PostPosted: Tue Oct 02, 2007 8:45 pm    Post subject: Reply with quote
Wow, amazing, you're really giving UVLayout a work-out on that mesh!
About how long did it take you to do that? I'm guessing there was probably some tedious manual labor in laying out those smaller pieces into the nicely organized lines; I can see they're center aligned, so you wouldn't have used packing boxes, and they don't have similar boundaries so the stacking wouldn't have helped either.
highlander_72
PostPosted: Tue Oct 02, 2007 11:20 pm    Post subject: Reply with quote
Many thanks for the comments, Phil! Smile
I didnt clock myself on this, but I am estimating it took me about 12-15 hours of work start to finish, including final tweaks and arranging the parts by hand. I am not sure if that is fast or slow by your or other peoples standards, but Layout did make it a breeze, as compared to any other method I could have use to get similar results.
It also took a bit longer than it could have since I went a wee bit back and forth on some parts. I did take my sweet time though, since I feel laying out solid UV's is such an extremely important step in mesh prepping.
I arranged them by hand into those pre-planned lines right after individual flattening . That helped organize the islands in a way I could still make sense of them and later place them where I would recognize their position on the 3D model in 2D texture space. It wasnt really all that tedious that way. Very Happy
Cheers!
PostPosted: Wed Oct 03, 2007 2:29 am    Post subject: Reply with quote
"I am estimating it took me about 12-15 hours ... not sure if that is fast or slow"
Me neither actually. I don't do a lot of complete UV edits from start to finish, and certainly haven't done anything as complex at that dragon. Anyway, like you said, you went back and changed some bits ... experimenting is part of the fun of UVLayout :-)
"I arranged them by hand ... It wasnt really all that tedious that way. "
Well, I wont promise anything is going to happen in a hurry, but I've made a note to look at this sometime; I'm sure I can tweak the stack or pack tools for these sorts of "center aligned" arrangements.
highlander_72
PostPosted: Wed Oct 03, 2007 4:38 am    Post subject: Reply with quote
Sounds great!
