how to run menu function in dos command?
Goto page 1, 2  Next
sunfun
PostPosted: Tue Jul 31, 2007 3:57 pm    Post subject: how to run menu function in dos command? Reply with quote
I want to run the menu function such as "send" "save dxf"...in plugin mode with dos command on windows,I have the next script :
I run the command :uvlayout.exe -plugin t.uvl , it is ok
and I creat the t.cmd with "exit" in it ,it is ok also.
but I creat the t.cmd with "Save DXF test.dxf ",it is nothing hanppen,why?
how can i run all the unlayout function(inculde option ) by command ?
thanks a lot!
yours sunfun.
r_knightly
PostPosted: Tue Jul 31, 2007 4:38 pm    Post subject: Reply with quote
as far as the documentation goes the only command "XXX.cmd" takes is "exit" also im pretty sure uvlayout has no .DXF support at the moment. Only .OBJ .PLY & .UVL are supported. Im pretty sure .DXF will triangulate your model to bits aswell, which is afaik in no way desirable. My application isnt yours though. Hope that helps
What app are you working with btw?
PostPosted: Tue Jul 31, 2007 6:10 pm    Post subject: Re: how to run menu funcation in dos command? Reply with quote
"but I creat the t.cmd with "Save DXF test.dxf ",it is nothing hanppen,why?"
Just like r_knightly says ... "exit" is the only thing that UVLayout accepts in the command file at the moment. If you can write a bit about why you want to be able to control UVLayout from the outside, I could have a look at expanding the list of accepted commands.
sunfun
PostPosted: Tue Jul 31, 2007 7:57 pm    Post subject: I just want to get outline after run for expanding Reply with quote
thanks for replies above ,I just want to get outline after run for expanding ,I can not get target file from the XXX.out,and when can I run the "run for" command outside the uvlayout.So I want to knowe how i can full contral the uvlayout from vb.net or just use any way in windows plat?
thanks again.
PostPosted: Tue Jul 31, 2007 8:09 pm    Post subject: Re: I just want to get outline after run for expanding Reply with quote
"... how i can full contral the uvlayout from vb.net or just use any way in windows plat?"
Got it ... you're the first to ask for that! Unfortunately there is no way currently to control UVLayout from another application, other than to get it to load a file and exit.
sunfun
PostPosted: Tue Jul 31, 2007 8:28 pm    Post subject: Re: I just want to get outline after run for expanding Reply with quote
I am regret .I have a application that made myself and it need the expand funcation form 3D to 2D , I think your uvlayeout is the best one.But now it is impossible .
Can I get any help just to do "load a XXX.obj then expand 3D to 2d then save the outline XXX.out" ?
thanks verymuch!
PostPosted: Tue Jul 31, 2007 10:45 pm    Post subject: Reply with quote
Email me one of your OBJ files and I'll see if I can get it to flatten and export the DXF automatically.
sunfun
PostPosted: Tue Jul 31, 2007 11:04 pm    Post subject: the test obj file Reply with quote
the attachment is test obj file ,you just flatten it and export the outline ,the DXF is not necessary , the same obj format is OK.
thanks !
test.rar
Download
 Filename:  test.rar
 Filesize:  22.31 KB
 Downloaded:  2699 Time(s)
PostPosted: Tue Jul 31, 2007 11:59 pm    Post subject: Reply with quote
Thanks, got the file ... I think I can do what you want without too much trouble ... should be able to get it into the next release, which will be early next week sometime.
sunfun
PostPosted: Wed Aug 01, 2007 2:58 pm    Post subject: I am waiting for ... Reply with quote
thanks,I am waiting for ...the best that can save all options and parameters which are satisfaction one time,then flatten it and export the outline automatically.
PostPosted: Thu Aug 02, 2007 6:27 pm    Post subject: Reply with quote
Got this working now, and have updated the plugin documentation; look under "Other Commands" in this posting ...
http://www.headus.com/phpbb/viewtopic.php?t=159
I hope to upload v1.21 later today, which will include this change.
PostPosted: Thu Aug 02, 2007 11:17 pm    Post subject: Reply with quote
UVLayout Beta v1.21 has been uploaded ... you can grab it from uvlayout.com/try. Oh, and you can now also set the load options from the command line; see that posting above for details.
sunfun
PostPosted: Fri Aug 03, 2007 12:40 am    Post subject: thank you very much! Reply with quote
thank you very much! I will try it soon.
sunfun
PostPosted: Fri Aug 03, 2007 4:14 am    Post subject: Re: thank you very much! Reply with quote
I have tested it and find something wrong:
every time ,when completed flatten and export ,it shows "cyeat.exe err"--to see attachment err.jpg,and it has a dumpxxx.txt .
and can i tick the Outline option as default,so I do not need tick it everytime.
and how can I know when flattening is completed,then I can do next.
thank you .
 Filesize:  74 KB
 Viewed:  52300 Time(s)
dump008732.txt
Download
 Filename:  dump008732.txt
 Filesize:  367 Bytes
 Downloaded:  1914 Time(s)
PostPosted: Fri Aug 03, 2007 6:35 pm    Post subject: Re: thank you very much! Reply with quote
"when completed flatten and export ,it shows "cyeat.exe err""
Look like you're hitting this problem ...
http://www.headus.com/phpbb/viewtopic.php?t=202
"can i tick the Outline option as default,so I do not need tick it everytime."
No, sorry, it currently doesn't remember the setting from session to session. But the way the plugin interface works is that the GUI can stay running, and you just keep feeding it new files to flatten, and the outline setting will then apply to all saved files.
And you know when the flattening has finished when the output file has been created. Get your application to watch for that file.
Goto page 1, 2  Next
Page 1 of 2
