Cinema 4D Plugin
umblefugly
PostPosted: Fri Aug 25, 2006 4:45 am    Post subject: Cinema 4D Plugin Reply with quote
Ive had for the longest time...well 6 or 7 months a plugin I made to load UVLayout from inside Cinema 4D.
Getting it to communicate ie send files back and forth between the 2 is beyond me though.
PostPosted: Fri Aug 25, 2006 5:38 pm    Post subject: Reply with quote
Are you using v1.14? Make sure you add -plugin to the command line ...
uvlayout -plugin whatever.obj
... and maybe better, specify a full path for the transfer OBJ, and to be sure, keep it simple (ie no spaces) ...
uvlayout -plugin C:/Temp/whatever.obj
Then just write your object to C:/Temp/whatever.obj and it should be loaded. If not, don't kill yourself trying to work it out ... this is version 1 of the plugin code, so it could be broken. Let me know and I'll add some sort of log or something to make it easier to debug.
umblefugly
PostPosted: Fri Aug 25, 2006 9:17 pm    Post subject: Reply with quote
Yes, im on 1.14 now.
All the plugin did before was load uvlayout for me.
Thx for the info Phil Smile
PickersAngel
PostPosted: Sat Nov 04, 2006 5:29 am    Post subject: Reply with quote
umble, did you ever get this working, and would you be willing to make it available to those of us who don't know how to script plug-ins?
Thanks!
umblefugly
PostPosted: Sat Nov 04, 2006 11:51 am    Post subject: Reply with quote
It will be free once done, just very busy lately, sorry Smile
Glad to see you here Smile
