westonmi
Posted: Tue May 22, 2007 8:41 pm Post subject: Smooth function not working |
Just trying out the new v1.19.2 and I can't get the new smoothing function to work. The 4 & 5 keys work great, but the 6 key doesn't do anything (I don't even get the brush outline). Any suggestions?
Running a AMD64 3200+ 2.01ghz, 1 gig ram and WinXP Home edition. |
Posted: Tue May 22, 2007 9:04 pm Post subject: |
Do you have Brush "Pin" turned on in the main GUI window?
Here's the relevant section from the User Guide ...
Brush Local Scale / Pin
When Local Scale is selected, the 4/5 hotkeys paint a local scaling into the polys under the brush; this has the effect of moving the UVs in that area in or out during any further flattening, while preserving the shape of the polys as much as possible.
When Pin is selected, the 4/5 hotkeys simply move the UVs in or out directly, disregarding any shape constraints and most likely reducing the quality of the UVs in that area. The UVs are pinned so that any subsequent flattening of that shell doesn't affect the new UV positions. Also when in this Pin mode, the 6 hotkey can be used to smooth UVs.
Smooth Boundary
When smoothing UVs using the 6 hotkey, this option determines whether shell boundaries are modified.
