bigbrainz
Posted: Mon Apr 23, 2007 11:41 am Post subject: Edge Locking |
| Is there a way to lock the edges without going through and pinning them individually? Thanks! |
Posted: Mon Apr 23, 2007 5:28 pm Post subject: |
You can pin the boundary of a shell by aiming the pointer at a boundary point and typing Shift-P. You can pin a smaller section by pinning a couple of end points first, then type Shift-P between them. You can pin everything inside a rectangle by aiming the mouse pointer at empty space and type Shift-P. And finally, you can use the G key to green select a number of polys, then aim the pointer at empty space and type G to get a menu where you can type P to pin all those points.
bigbrainz
Posted: Tue Apr 24, 2007 10:50 am Post subject: |
| Ah, I knew there was a brilliant way to do it--thanks! |
