Two bug reports
dude5487
PostPosted: Sun Apr 01, 2007 6:51 pm    Post subject: Two bug reports Reply with quote
Loaded up my obj with a previous UV layout on it. While in UV view hit Shift D and it crashes. Loaded up the obj with a clean slate, went into edit mode, cut up my leg all fine and split it up, when I hit D to drop the objects into UV space I got an immediate crash.
I have attached both the text files from the errors.
Edit: Just got another error. I loaded up the obj again for a fresh start, I split along a diff spot now with the symetry on, I forgot to mention that it was on in the previous two errors. I cut along the arms, split where I wanted the the seem to be, this time I wanted to save right off to make sure I kept my work, and right when I hit save I got another error. Text is attached again.
PostPosted: Sun Apr 01, 2007 7:59 pm    Post subject: Reply with quote
Thanks for the crash reports! Looks like this bug turning up again ...
http://www.headus.com/phpbb/viewtopic.php?t=202
dude5487
PostPosted: Sun Apr 01, 2007 8:23 pm    Post subject: Thanks for the response! Reply with quote
Thanks for the quick response. I am not home and will give it a go when I do get home.
What if this does not fix the problem? What would be the likely next step?
PostPosted: Sun Apr 01, 2007 8:32 pm    Post subject: Reply with quote
Zip up your OBJ file and email it to me if you don't mind me seeing it. I can then try the undrop etc here to see if I can get it to crash as well.
