.obj scale bug?
garyhanna
PostPosted: Mon Mar 19, 2007 5:10 pm    Post subject: .obj scale bug? Reply with quote
I have seem to only come across this in the latest version or 2. I am running ver. 1.17.1.
After creating my UVs in UVLayout, I import the created .obj into Maya 8.5. The imported obj now comes in with scale about zero'd out. I have to scale it up to .001 just to see it.
I'm not sure if this is a bug or not.
Thanks
PostPosted: Mon Mar 19, 2007 6:08 pm    Post subject: Reply with quote
Sounds like a bug! I might have fixed it already ... the next update will include changes to the OBJ import/export code that hopefully puts to rest all these scaling problems. I'll be uploading that later this week or early next.
There's a work-around if the scaling is a problem ... use the Update button instead of the Save.
garyhanna
PostPosted: Mon Mar 19, 2007 9:34 pm    Post subject: Reply with quote
Great!
Thanks much!
PostPosted: Fri Mar 30, 2007 1:58 am    Post subject: Reply with quote
OK, I finally got the fix (hopefully!) for this uploaded. See ...
http://www.headus.com/phpbb/viewtopic.php?p=1636#1636
garyhanna
PostPosted: Fri Mar 30, 2007 10:24 am    Post subject: Reply with quote
Thanks Phil! I'll give it a go.
