Be able to move several non-identical pieces at same time
Gendri Cour
PostPosted: Sat Dec 30, 2006 8:42 am    Post subject: Be able to move several non-identical pieces at same time Reply with quote
hi
Return back, yellow blink flattened shape - it very good !!!!
We with impatience of it wait :
automatically packing of the ready form
Group/Ungroup shape for move, rotate, scale
automatically cut - seam material ID checkbox in windows "Load'
PostPosted: Sat Dec 30, 2006 5:09 pm    Post subject: Re: uddon wish list Reply with quote
Yes, I've got that one on the list.
You can sort of do this already with the lock tools; use the L hotkey to stretch a box around the shells/shapes you dont want to transform.
I was thinking that UVLayout could do a visibility analysis of each edge, and it would use that information to automatically select some initial seams. Is that what you meant?
Yes, on the list too.
Gendri Cour
PostPosted: Sat Dec 30, 2006 11:59 pm    Post subject: Re: uddon wish list Reply with quote
It not so conveniently as though would be desirable
I have made UV and I stack ready parts on a field of a texture
I have laid many pieces as it is pleasant to me - but for some piece, not enough place. We make group and we move all earlier laid together so that the place has sufficed the not sufficing piece. To move each ready piece one behind another, it is inconvenient in this case
I know English insufficiently and have badly explained that I wished to tell, and have insufficiently well understood your answer. I shall try to explain again.
I have ready model at which there are some materials (material ID). I import this model in UVLayout and I wish to see a separate material as a separate piece (аuto cut, green seam). Addition of such function for import it will be good
pc
That you tell, to return yellow blink flattened shape ???
Lewi
PostPosted: Sun Dec 31, 2006 5:41 am    Post subject: Reply with quote
Hi, have you tried the "autofit" checkbox to get a quick fit for your laid out square mapping ?
PostPosted: Sun Dec 31, 2006 5:02 pm    Post subject: Re: uddon wish list Reply with quote
Sorry, I don't understand what you are trying to do. Maybe a couple of screen shots would help explain it? If you move the mouse pointer into the 3D window and hit the PrintScreen or F8 keys, then the 3D window image is saved into a snap*.jpg file.
Got it! Yes, someone else had requested this too. When I work on the code to handle materials, this will be part of it.
Hold down the space bar. Have a read of this posting though ...
http://www.headus.com/phpbb/viewtopic.php?t=143
Some people are having problems getting it to work, but there appears to be a workaround.
Gendri Cour
PostPosted: Mon Jan 01, 2007 12:19 pm    Post subject: Re: uddon wish list Reply with quote
no no, I speak absolutely about other...
Earlier was so http://www.dreamwoods.ru/Images_temp/UVLayout_v.1.12.swf
Now became so http://www.dreamwoods.ru/Images_temp/UVLayout_v.1.16.8.swf
I ask to make as was in UVLayuot v.1.12
PostPosted: Mon Jan 01, 2007 4:44 pm    Post subject: Reply with quote
Ahhh, I see! You want the yellow flashing border back. The reason I turned it off was because it slowed things down on the heavier meshes. I'll see if I can put it back for at least the lighter meshes.
Gendri Cour
PostPosted: Mon Jan 01, 2007 11:29 pm    Post subject: Reply with quote
hi
Excellently, we began to understand each other Cool
yellow flashing border is a question of ergonomics. The yellow blinking informs the user that the program works, and what action is carried out present time at first sight on the screen
Have gone further? Cool
Here video shows my work in 3D max http://www.dreamwoods.ru/Images_temp/clip0002a.avi
Pay attention - I allocate with the clamped key of the mouse and I move many pieces simultaneously...
This strongly does not suffice in UVLayout. The mode offered by you active/unactive is similar to mode freeze/unfreeze in 3D max. It again a question of ergonomics.
In your mode active/unactive, it is necessary to add with a mode of plural allocation (movement) by the clamped key of the mouse - then will work much more conveniently.
moochie
PostPosted: Tue Jan 02, 2007 4:22 pm    Post subject: Reply with quote
Gendri Cour wrote:
..I move many pieces simultaneously. This strongly does not suffice in UVLayout.
Yes, I agree. Multiple instances of identical parts can be moved using the stacker tool, but it would be useful to be able to move several non-identical parts at the same time. Please.
Separate issue .. any chance of a brief 'heads up' to the regulars who haven't parted with their cash yet, a couple of weeks before you release the commercial version, please? I don't want to miss out on the pre-release special offer. btw, I've been a good boy and been singing your praises in a couple of modeling forums (I'm such a toady). Laughing
PostPosted: Thu Jan 04, 2007 9:04 pm    Post subject: Reply with quote
No problems, "move multiple pieces at same time" has been added to the list!
Don't panic ... I was going to give everyone 1month notice of the change.
PostPosted: Wed Jan 17, 2007 10:27 pm    Post subject: Reply with quote
The yellow flashing border is now back ... grab v1.16.9 if you want this.
