How do I enable C/W on Blue Seam?
jaw312
PostPosted: Tue Oct 03, 2006 9:37 pm    Post subject: How do I enable C/W on Blue Seam? Reply with quote
My obj comes in with a blue seam right down the center (from mirroring geom).
But I can't use C or W or anything on this line.
How do I "un-Blue" it?
Thanks
jaw
PostPosted: Tue Oct 03, 2006 10:24 pm    Post subject: Re: How do I enable C/W on Blue Seam? Reply with quote
The blue edges indicate a hole or seam in the geometry, and UVLayout tries very hard not to touch the geometry at all, its just for editing UVs. If you need to fill in a hole, or weld a seam in the geometry, then that currently has to be done externally, usually in whatever application you used to create the geometry in the fist place.
