Asimov
Posted: Mon Oct 11, 2021 4:09 pm Post subject: flattening problem |
I am using uvlayout v2.09 something and I tried flattening a simple shape. Tried this on a different model and it worked fine. Now this shape is very small on the model, but for some reason it will not flatten.
I have tried F
Shift F
Space F
No matter what method of flattening it always screws up into a ball and gets trashed.
Is there a way to flatten this without it getting screwed. I am wondering if it is a scale problem as this is a very small part of the model.
There is only slight curvature not, much s it shouldn't have too much trouble flattening.
EDIT: I can planar map this in 3ds max with no problems, so I will probably have to unwrap this in max instead of uvlayout, which is a shame |
Asimov
Posted: Tue Oct 12, 2021 2:34 am Post subject: Only solution so far |
My model is large, but this part of the model is really small. I found out if I select polygons and detach this piece of the moden and send to uvlayout it flattens fine. So I am guessing it is a scaling issue. I will have to detach each part, unwrap and then re-attach it seems.
Not sure if that is the best solution, but it works so far |
Posted: Sun Oct 17, 2021 8:35 pm Post subject: |
| Can you give me some idea of the relative sizes? That is, overall length of the main object, and then length of that small piece. I can then make something similar here to test with. |
