redspark
Posted: Wed Feb 17, 2021 6:02 pm Post subject: MacOS & UVLayout |
Not long ago, I upgraded all of my MacBook to a new M1 MacBook running Big Sur. Needless to say, UVLayout doesn't work natively. However, I was able to get it installed as a Windows Application using CrossOver. The only problem is that I use a Dongle which isn't recognized under CrossOver. I don't know if UVLayout will work completely under CrossOver or not but I'd like to give it a try since it's pretty much my only hope.
Is it possible for me to switch to an Ethernet lock? Thanks.
James |
TBane
Posted: Tue Jun 29, 2021 3:55 am Post subject: |
| That’s so weird; in the world of switching, particularly “dumb switching†you’d take a LAN port on your home router, plug in one end of that 50ft Ethernet to it(doesn’t matter cat5 or cat6) then plug in the other half to any of the unmanaged/dumb switch ports and then plug in your devices and all should be ok. <<Links blocked until user has been cleared>> |
