UVs often rotate when flattening? Why and how to Fix?
Tragic
PostPosted: Thu Feb 06, 2020 9:19 pm    Post subject: UVs often rotate when flattening? Why and how to Fix? Reply with quote
Often when I drop a cut to the UV space to flatten, the UVs rotate.... how can I stop this or fix the orientation.
Example:
Super Simple... this is just a box... but this will demo the issue.
I split off the bottom face and drop it
I press F and it flattens... all good right? This is how I think it should work.
ERROR
I cut each face like so... drop to the UVspace and then....
As you can see when this flattens... it rotates the UV to some unknown degree... meaning I would have to eyeball it back into place.... Why does this happen and how can I stop it or fix it without eyeballing. This example is trivial but it dose this for a lot of organic complex shapes as well as large non-organic shapes.
Anyhelp would be apreciated.
dave123
PostPosted: Sat Jun 26, 2021 12:54 am    Post subject: Reply with quote
So I want to say:
Select first UV shell element
then place it to 0.0.0
Select second UV Shell element
Dubbie
PostPosted: Sun Nov 14, 2021 12:22 pm    Post subject: Reply with quote
Hold down Ctrl, then mouse-over an edge and press one of the arrow keys. This will align the edge to the arrow key direction.
