deanbroadland
Posted: Wed Sep 25, 2019 12:56 pm Post subject: Problems launching uvlayout 2.11 from Maya shelf in Linux |
Hi!
The following works fine in 2.10.03, but fails in both 2.11.01 and 2.11.02.
Repro:
- on Linux (CentOS 6.4)...
- in Maya...
- click the Info button on the UVLayout shelf (runs uvlayout_open)
- in the UVLayout Plugin GUI that comes up, check "Turn On Debugging" and click "Run UVLayout"
- no UVLayout comes up, Maya script editor shows:
| Code: | // save [workpath]/maya/uvlayout/uvl1736.obj
// load [workpath]/maya/uvlayout/uvl1736.out
// Home Undefined. Run 'Install Maya Plugin' from UVLayout GUI/uvlayout-maya-log uvl1736.obj > /dev/null 2>&1 & |
- checking $HEADUS_HOME, it is set correctly to the root of our uvlayout 2.11.01/02 install
I was able to temporarily fix this with custom installs of 2.11.01 and 2.11.02, making slight tweaks
to lib/maya/uvlayout_home.mel and lib/maya/uvlayout_open.mel, to basically change a few things back to how 2.10.03 had them set up:
lib/maya/uvlayout_home.mel:
* comment out return line, replace with contents of uvlayout_home() from 2.10.03
* near end of uvlayout_run() (in Linux-specific else clause), comment out $home and $bin lines, replace with: string $bin = "uvlayout-maya";
Are we maybe missing some install step, or possibly doing something else wrong? Thanks!
P.S. I haven't posted here before (that I can recall), so let me know if you need any other info. |
