Optagon
Posted: Tue Oct 30, 2018 1:49 am Post subject: Box Locked shells pack extremely close to other and overlap. |
I often pack shells where overlapping ones need to be treated as one, so I use "Box and Lock Overlapping". But this feature confuses the Pack All routine, more often than not my shells are packed extremely tightly against each other, where i have to zoom way in to even see that there is a gap. It's also pretty common that some shells will completely overlap others, this is usually the case if I send multiple objects together into UVLayout using the Maya plugin.
If I remove all the locks and boxes and pack the same uv's, the shells are nicely spaced.
Please get this working, I need this
v.2.09.04 |
