Modo 12v1 Plugin
Wyattfox
PostPosted: Tue Apr 03, 2018 6:26 pm    Post subject: Modo 12v1 Plugin Reply with quote
Hi Community,
The Foundry updated Modo (12v1) last week and this has seemed to have broken the plugin Spp_ wrote (https://www.youtube.com/watch?v=6LoQoFSekMg). It was working amazinly great in Version 11v3!
Would any talented programmers, be able to help a fellow Headus user out!
Thanks
Wyattfox
syphon_drift
PostPosted: Sun Nov 04, 2018 9:01 am    Post subject: Reply with quote
Replace the 'uvlayout_bridge.py' in your Luxology scripts folder with the one attached.
If you've followed the Youtube video guide and set up your temp directory - tmp_f - on C:/ and dropped the .CFG and .py files into the correct directories this update should work in Modo 12 (tested and working in my Modo 12.1v2)
Not a programmer by any means, I just tracked the error line that Modo was generating as being faulty in the script and deleted it to see what would happen and that fixed the issue.
 Filesize:  71.56 KB
 Viewed:  73342 Time(s)
uvlayout_bridge.rar
Download
 Filename:  uvlayout_bridge.rar
 Filesize:  1004 Bytes
 Downloaded:  2277 Time(s)
wskui
PostPosted: Fri Feb 01, 2019 4:46 am    Post subject: not work in 12.2v1 Reply with quote
Hello, syphon_drift, thanks. But the 'uvlayout_bridge.py' script don't work in Modo 12.2v1
 Filesize:  33.09 KB
 Viewed:  72880 Time(s)
