Problem with OBJ From UVLayout to Maya
warren
PostPosted: Wed Mar 08, 2017 3:56 am    Post subject: Problem with OBJ From UVLayout to Maya Reply with quote
I've modeled a hair style in Maya and exported it as an OBJ file to be used in UVLayout. I created my UV Map saved it as an OBJ file and reimported it into Maya and I received a message stating the following:
"Your OBJ file contains faces shared by multiple groups. Maya cannot create multiple objects for this file. A single mesh object will be created instead. The OBJ group information will be captured in Maya sets."
PostPosted: Thu Mar 09, 2017 11:36 pm    Post subject: Reply with quote
Which version of UVLayout are you using, and which version of the plugin (you can get this from the plugin info window)?
