litote9
Posted: Fri Jan 27, 2017 6:03 am Post subject: Subdivision mesh opens wrong |
I created a Subdivision Surface mesh in C4D and exported as an OBJ. When I open it in UVLayout using the Type: SUBD option, it opens, but seems to mix the Subdivision Surface mesh with the original child mesh of the Subdivision Surface. So it shows a mix of large and small polygons as if the two are overlaying in some areas.
What am I doing wrong?
P.S. It seems to be the fault of C4D. Version R18 exports this odd mix, whereas earlier versions didn't. I probably should pose my question on the C4D forum instead -- sorry. The temp fix would be to convert the Subdiv version. |
