Crash when moving a box
furash
PostPosted: Mon Jan 16, 2017 3:09 am    Post subject: Crash when moving a box Reply with quote
Hi, when I'm trying to move a box with shells on which Rectify was applied and grabbing empty space instead of corner UVLayout crashes. Version 2.10.0 Windows 8.1
Updated: works not only on with Rect shells, but just clicking outside of the box and then trying to drag it around also result in crash.
Here's a video with demo.
https://youtu.be/kZnnxPrqpLo
PostPosted: Mon Jan 16, 2017 9:41 pm    Post subject: Reply with quote
Thanks for taking the time to make a video!
In the latest version I added the ability to move a box around without having to grab a corner handle ... it worked fine in my testing, and still does now when I test it, but obviously something is broken if you're getting a crash.
If you use the old method (i.e. MMB click on the corner handles only) does that avoid the crash?
furash
PostPosted: Mon Jan 16, 2017 11:52 pm    Post subject: Reply with quote
The crash doesn't occur when using corner grab, only when new method is used.
I tested it on 3 different windows 8.1 PCs, demo version for Mac and even demo on virtual Windows XP machine. Every time it crashes once I try to move a box with new method. In rare cases it works for one time, but after I release mmb and click outside of the box and try moving it again - the crash occurs.
PostPosted: Fri Jun 23, 2017 12:22 am    Post subject: Reply with quote
If you go to your uvlayout.com Support Extras page, you'll find the latest v2.10.01 beta there.
I must have made a change somewhere that had the side-effect of fixing this bug, because I cant get it to crash now.
