How do I save out a imge of the UVs so I can paint on it?
Tragic
PostPosted: Sun Dec 04, 2016 8:24 pm    Post subject: How do I save out a imge of the UVs so I can paint on it? Reply with quote
Once I have made my UVMap... how can I save the it as a image file to take into photoshop and pain on?
(New user)
PostPosted: Sun Dec 04, 2016 8:27 pm    Post subject: Reply with quote
That's the "Render" tools ...
http://www.uvlayout.com/doc/User_Guide:_Render
Tragic
PostPosted: Sun Dec 04, 2016 8:33 pm    Post subject: Reply with quote
Thanks...
ALso.. I know this is stoopid, but I just am testing the software for the first time... and I did a big layout.. saved as a OBJ and loaded it and all the UVs are gone?
How do you save the file for importing back into another application?
PostPosted: Sun Dec 04, 2016 8:38 pm    Post subject: Reply with quote
You don't have to do anything special to save the UVs.
When loading into UVLayout though, make sure "Edit" is turned on in the Load Options window if you want to edit existing UVs. You should do that now anyway, load the OBJ you just saved back into UVLayout to double-check that the UVs are in there. If they are, then you need to check your import options in the other application.
Tragic
PostPosted: Sun Dec 04, 2016 8:41 pm    Post subject: Reply with quote
oh right... yeah.. I had the "new" button selected!! lol
Can you assign textures inside UVLayout?
PostPosted: Sun Dec 04, 2016 8:46 pm    Post subject: Reply with quote
You can create new "Material" groups and assign selected polys to them, but there's no tools in UVLayout for actually defining what those materials look like.
But when you load the OBJ into your modeling/animation package, those material assignments should be preserved and then you can edit what they look like.
http://www.uvlayout.com/doc/User_Guide:_Groups#Editing
