Getting UV's inside Headus from other software
jhonut
PostPosted: Wed Sep 14, 2016 2:16 am    Post subject: Getting UV's inside Headus from other software Reply with quote
Hi I would like to know if there is a way to import meshes already UV-ed from other software like maya then to use on them the packing algorithm?
PostPosted: Wed Sep 14, 2016 5:22 pm    Post subject: Reply with quote
Yes, when loading the OBJ, just make sure that "Edit" is turned on in the load options. If you have "New" on, then all existing UVs are deleted.
