bencowellthomas
Posted: Mon Aug 08, 2016 5:53 am Post subject: relax brush doesn't completely undo |
I've noticed that if I use the relax brush and then undo, the uv's seem to 'remember' the relaxation even if I hit undo.
for example .. flatten something, relax a corner then hit undo to remove it. Now hit flatten again and I find that the uv's that were relaxed with the brush now take on that relaxation again. The only way to clear the values seems to be to undrop the shell and then bring it back into the uv space.
Am I going mad or do other people see this ?
cheers
ben |
Posted: Fri Aug 19, 2016 6:58 pm Post subject: |
Can you explain in a bit more detail what hotkeys you're using and in what sequence? I've tried to get the memory thing happening that you described, but aren't seeing anything odd happening with the usual F and B keys.
bencowellthomas
Posted: Sat Sep 03, 2016 5:10 am Post subject: |
It's the X key that's giving me this behaviour.
thanks
ben |
