Trace repeats?
oesponda
PostPosted: Tue Aug 02, 2016 4:12 pm    Post subject: Trace repeats? Reply with quote
Hello, is it possible to set a number of repeats when an image is used by the trace feature? Something similar to the - and = keys when displaying the default textures.
Any idea on how to do it or if it-s possible at all?
Orlando
PostPosted: Tue Aug 02, 2016 5:28 pm    Post subject: Reply with quote
Sorry, you cant change the repeat of the "Trace" image, but you can change the file used for the second texture image (i.e. the checker with the numbers over it).
Open up the preferences and click the arrow after "Map" and there you can select the image you want to use for the "T" key texture.
oesponda
PostPosted: Wed Aug 03, 2016 5:12 pm    Post subject: Reply with quote
Thanks Phil, that trick is more than enough for what I need.
Orlando
