Is there a Linux Installation?
MEL3D
PostPosted: Thu Aug 03, 2006 5:33 pm    Post subject: Is there a Linux Installation? Reply with quote
I've searched your site for an info about Linux installation. Not much of Admin in Linux
OS and if it is not a .rpm format I have a problem . Any chance you can post install info for Linux ,Suse 10.1
Thanks a lot. 8)
View user's profile Send private message AIM Address
PostPosted: Thu Aug 03, 2006 6:45 pm    Post subject: Reply with quote
If you go to uvlayout.com/try, there's a link to the Linux download page at the end of
the first line. So in there is the TGZ download, and the install instructions. Its just
a Gzip'd tar file, so in some ways is easier to install than an RPM. You dont have to
have sysadmin rights, it can be done as a normal user into your own home directory.
Just change the "/usr/local/" in step 1 to whatever you home directory is, and it should
be plain sailing from there on.
Also see the note down the bottom of the page about OpenMotif 2.2.0.
I havent tested UVLayout under anything other that Redhat though.
