Posted: Mon Jun 01, 2015 10:58 am Post subject: Optimize - Run for |
Hey,
Somewhere along the line the optimize tool has changed, by that I mean that the length of time it spends solving the wrap has been reduced, and adding more minutes has no affect either. For particularly complex meshes, I used to add ten or more minutes and walk away while it solves it.
Some meshes when dropped, wont be properly unwrapped using the optimize tool, so I have to use the bloat unwrap (shift-F) to force it to unwrap. This is a problem when you have multiple meshes.
The images attached has 8 shells, the ones on the left were done using Shift-F, the ones on the right have been optimized several times.
This used to work much better.
What happened?
Cheers,
Michael |
