Can't pack in 5 tiles
MIster3d
PostPosted: Sat Mar 14, 2015 4:49 pm    Post subject: Can't pack in 5 tiles Reply with quote
Hello! Great tool, but I miss something. I try to pack the model into 5 squares (tiles). I made some pieces smaller and made them "local", so they don't scale. Then I fixed all the needed pieces in tiles where I want them to be left (# on them). But when I start to pack, they start to move where they want, obeying the # sign on them. Maybe I do something incorrectly? Thank you!
What I need that the pieces don't resize, and stay in squares where I put them.
PostPosted: Wed Mar 18, 2015 5:22 pm    Post subject: Reply with quote
I'm not sure why the "#" tagging isn't working for you, but if you want to leave all shells where they are, tick the "Lock All To Tile" in the pack options.
MIster3d
PostPosted: Wed Mar 25, 2015 4:11 pm    Post subject: Reply with quote
Thank you! The locking doesn't work for some reason. Even if I press it, the shells still move in different udims. As you can see, the shells are resized, though I want the head to be as it is, as I manually packed it.
For some reason I don't get email notifications, though I'm substribed.
PostPosted: Wed Apr 01, 2015 7:27 pm    Post subject: Reply with quote
Could be its confused because everything is blue (too large). See below for a hidden trick to fixing the global scaling, then see if the packing works any better after that.
