HolaBlackDavy
Posted: Fri Sep 12, 2014 3:20 pm Post subject: UVLayout Send to 3ds Max problem! |
Hello, i just installed UVLayout and i was doing some test and this problem came up!
When im done with UVs and pack them, i press Send and the UVs transfer to 3ds Max but they are distorted. Any ideas how can i solve this ? |
Posted: Fri Sep 12, 2014 4:56 pm Post subject: |
I dont use 3ds, but the UVs in the UV edit window look fine, so I'm wondering if you have two cylinders on top of each other? Or maybe multiple UV sets/layers, and the distorted one is being viewed on the mesh but not the good ones as seen in the UV view.
Asimov
Posted: Sun Apr 05, 2015 5:25 pm Post subject: |
I too am having the same problem. I haven't actually got headus but I am trying it out at my friends house.
I want to buy headus because I like it, but this problem is a big problem.
If I export to obj first and load that into headus and then load the obj into max the uvs are fine, and not distorted, apart from the fact the model comes in lying on it's back.
So I am guessing this problem is to doing with the max script to send the headus to max.
My friend is using 3ds max 2015 and the uvpipe mod by miauu.
I am wondering if it is because the script has not been updated when max 2015 came out.
Please let me know if anyone has a solution. I don't want to buy this product if it can't send to max.
Plus the other problem is that I can't unwrap my 90000 poly model. Headus just crashes on load. |
Asimov
Posted: Sun Apr 05, 2015 8:03 pm Post subject: |
I found out that if I use a different script then I can send the uvs back to max ok.
The only problem is I have downloaded a few and don't know who I got this one from.
I will try and find out and let you know. The script I found only lets you send one object to headus though.
I had a look in the file to see who wrote it, but all it say is rt_uvpipe |
Asimov
Posted: Mon Apr 06, 2015 2:23 am Post subject: Can't find which script I used |
Hi all,
As I said in my last post I have tried a few scripts to get max working correctly with uvlayout and I know which script works, but it does not identify in the script who wrote it. Perhaps if I paste the script here someone will recognise it. This script only works with single objects though, and not multiple.
The ones that don't work in max 2015 are the HamLT one and the miauu. When I say they don't work they go through the actions but some how stretch all the materials. I wish I could learn how to modify these scripts. I know C++ but not how the script language works.
Code: |
macroScript rt_uvpipe
category:"rt uv tools"
tooltip: "Headus Uvlayout bridge"
Icon:#("uvpipe",1)
local turnToPoly
local uvLayoutBin
local uvLayoutLaunchOptions = " -plugin"
local uvLayoutTemp = "c:\\"
local uvLayoutNode
local uvLayoutDummyNode
local uvLayoutMeshMode ="Poly"
local uvLayoutUVMode = "Edit"
local statusLine
fn importObjUvs nNode fileName =
local mapChan = 1
local mapVerts = #()
local mapfaces = #()
local file =openfile fileName
if file !=undefined then
while (not (eof file)) do
cl = readline file
tokens = filterstring cl " "
case tokens[1] of
"vt":
-- format "tvert: %, %\n" tokens[2] tokens[3]
append mapVerts [tokens[2] as float,tokens[3] as float,0]
"f":
tokens = deleteItem tokens 1
--format "face: %\n" tokens
local mapFace = #()
for i = 1 to tokens.count do
subToken = filterString tokens[i] "/"
append mapFace (subToken[2] as integer)
--print mapFace
append mapFaces mapFace
close file
if (classof nNode == editable_poly) then
numFaces = polyop.getNumFaces nNode
polyop.setMapSupport nNode mapChan true
polyop.setNumMapVerts nNode mapChan mapVerts.count
polyop.setNumMapFaces nNode mapChan mapFaces.count
numVerts = mapVerts.count
for i = 1 to numVerts do
polyOp.setMapVert nNode mapChan i mapVerts[i]
for i = 1 to numFaces do
polyOp.setMapFace nNode mapChan i mapFaces[i]
fn exportObj nNode fileName =
local mapChan = 1
local numFaces = polyop.getNumFaces nNode
local numVerts = polyop.getNumVerts nNode
local numTVerts = polyop.getNumMapVerts nNode mapChan
local matLib = #()
local materialList =#()
local numMaterials = 1
local filenameStub = filterString filename "."
local mtlFileName = filenameStub[1] + ".mtl"
local currentMtl = ""
fn getMaterialByID nNode ID =
mat = nNode.Material
if classof mat ==multiMaterial then
if ID > mat.materialList.count then
newIdx = mod ID mat.materialList.count
return mat.materialList[newIdx]
else
return mat.materialList[ID]
else
if mat == undefined then
mat = standardmaterial()
mat.name = nNode.name + "_mat"
return mat
fn safeMatName matName =
filteredMatName = filterString matName " -"
matName = ""
for element in filteredMatName do
matName = MatName + element
matName
local file = createfile fileName
if file != undefined then
format "# RT_OBJ Exporter\n" to:file
format "# % Verts\n" numVerts to:file
format "# % T Verts\n" numTVerts to:file
format "# % Faces\n" numFaces to:file
format "mtlLib %.mtl\n" (getFilenameFile mtlFileName) to:file
get_vert = polyop.getVert
get_tVert = polyOp.getMapVert
get_face_verts = polyOp.getFaceVerts
get_map_face = polyOp.getMapFace
get_face_ID = polyOp.getFaceMatID
local pf = 100/(numVerts + numTVerts + numFaces)
vert = get_vert nNode i
format "v % % %\n" vert[1] vert[2] vert[3] to:file
for i = 1 to numTVerts do
tVert = get_tVert nNode mapChan i
format "vt % % %\n" tVert[1] tVert[2] tVert[3] to:file
format "g %\n" nNode.name to:file
faceVerts = get_face_verts nNode i
faceMapVerts = get_map_face nNode mapChan i
faceVertCount = faceVerts.count
faceMatID = get_face_ID nNode i
faceMat = getMaterialByID nNode faceMatID
if faceMat != currentMtl then
matName = safeMatName faceMat.name
format "usemtl %\n" matName to:file
appendifUnique matLib matName
currentMtl = faceMat
format "f" to:file
for j = 1 to faceVertCount do
-- f v/vt/vn
format " %/%" faceVerts[j] faceMapVerts[j] to:file
format "\n" to:file
close file
--export the .mtl file
file = createFile mtlFileName
for mat in matlib do
format "newmtl %\n" mat to:file
format "kd 1.0 1.0 1.0\n\n" to:file
close file
fn UvLayoutSend nNode =
local fileName = (uvLayoutTemp + nNode.name +".obj")
local uv_mod = unwrap_uvw()
if ((classof nNode) != editable_poly) and ((classof nNode) != polyMeshObject) then
ePolyMod = edit_poly()
addModifier nNode ePolyMod
addModifier nNode uv_mod
uvLayoutDummyNode =copy nNode
uvLayoutDummyNode = convertto uvLayoutDummyNode editable_poly
deleteModifier nNode uv_mod
exportObj uvLayoutDummyNode fileName
uvLayoutLaunchOptions = " -plugin," + uvLayoutMeshMode + "," + uvLayoutUVMode
shelllaunch uvLayoutBin (uvLayoutLaunchOptions +" " +filename)
fn uvLayoutKill =
print "sending kill signal"
file = createFile (uvLayoutTemp + uvLayoutNode.name + ".cmd")
format "exit" to:file
close file
fn uvLayoutRecieve nNode =
--import the uvs into the dummy node
importObjUvs uvLayoutDummyNode (uvLayoutTemp + uvLayoutNode.name + ".out")
--copy the imported uvs from the dummy to the stack of the working node.
channelInfo.copyChannel uvLayoutDummyNode 3 1
channelInfo.pasteChannel nNode 3 1
uvLayoutNode.modifiers[1].name = "UVLayout UV's"
uvLayoutKill()
--deselect and reselect the working node. this will cause the stack display to refresh.
select uvLayoutDummyNode
select nNode
delete uvLayoutDummyNode
fn uvPipeInit =
local scriptsDir = getDir #Scripts
uvLayoutTemp = sysInfo.tempdir + "\\"
if (doesFileExist (scriptsDir +"\\"+"uvpipe\\uvpipe.ini")) then
uvLayoutBin = getINISetting (scriptsDir +"\\"+"uvpipe\\uvpipe.ini") "Settings" "bin"
print uvLayoutBin
else
uvLayoutBin = getOpenFileName caption:"uvlayout binary" filename:"uvlayout.exe" types:"Executable(*.exe)|*.exe"
makeDir (scriptsDir +"\\"+"uvpipe")
setINISetting (scriptsDir +"\\"+"uvpipe\\uvpipe.ini") "Settings" "bin" uvLayoutBin
rollout r_uvPipe "UV Pipe"
pickbutton pb_send "select object to start"
radiobuttons rb_meshMode "Mode:" labels:#("Poly","SUBD") default:1
radiobuttons rb_uvMode "UV Mode" labels:#("New","Edit") default:2
timer tmr_checkForUvs "wait" interval:500 active:false
on rb_meshMode changed mode do
mm = #("Poly","SUBD")
uvLayoutMeshMode = mm[mode]
on rb_uvMode changed mode do
um = #("New","Edit")
uvLayoutUVMode = um[mode]
on pb_send picked nNode do
uvLayoutNode = nNode
UvLayoutSend uvLayoutNode
tmr_checkForUvs.active = true
on tmr_checkForUvs tick do
if doesFileExist(uvLayoutTemp +uvLayoutNode.name+".out" ) then
tmr_checkForUvs.active = false
uvLayoutRecieve uvLayoutNode
on execute do
uvPipeInit()
createDialog r_uvPipe
Asimov
Posted: Mon Apr 06, 2015 7:20 am Post subject: |
Hi all,
I believe the only script that works for me is the R. Knightly script.
It only loads in one object at a time unlike the newer ones, but it works well.
Like I said the newer ones screw up the uvs for some reason.
Here is a link
http://www.headus.com/phpbb/viewtopic.php?t=402
Sorry it took so long to find the one that worked. It's just I installed 3 or 4 scripts and they all sent back to max, but I found the link above is the only script that does it properly.
Took me a while. I downloaded all the scripts again, and then matched the one that was the same as the one I had in max.
So if you have max 2015 the older script works, whereas the new ones don't. |
