Problem how can I stop the bloatfunction
garycrump
PostPosted: Mon Jul 24, 2006 6:17 pm    Post subject: Problem how can I stop the bloatfunction Reply with quote
I am having problem stopping bloat function the space bar is only pausing how can
I get it to stop completely so I can continue working.
PostPosted: Tue Jul 25, 2006 3:32 am    Post subject: Reply with quote
Hmm, the space bar should be stopping it, not just pausing. Instead of just
tapping the space bar, try holding it down, wait for the "release space bar"
message, and see if that helps.
crumbly
PostPosted: Fri Jul 28, 2006 4:32 am    Post subject: Reply with quote
I had this problem too. It seems to happen when you hit the space bar while the cursor is over the unfolding UVs. Try moving the cursor over an empty part of the screen before you tap the space bar.
PostPosted: Fri Jul 28, 2006 8:27 am    Post subject: Reply with quote
Thanks for the tip! Actually I couldnt reproduce the problem here, but it sounds
like it could be a common problem, so I'll have a closer looks at it.
garycrump
PostPosted: Fri Jul 28, 2006 10:13 pm    Post subject: Reply with quote
Thanks Crumbly that did the trick.
You were right It was the cursor over the operation that was causing the problem.
Works great now.
Ales Dlabac
PostPosted: Fri Dec 01, 2006 9:04 am    Post subject: Reply with quote
same issue for me. I have to move out arrow outside of shell and then hit the space.
PostPosted: Fri Dec 01, 2006 5:25 pm    Post subject: Reply with quote
Yeah, again I couldn't get it to go wrong here, but I'm moved this thread onto the "Bug Reports" list so it doesn't get forgotten about.
