edwins3D
Posted: Fri Aug 08, 2014 4:40 am Post subject: Headus UVLayout Plugin not working in Maya 2014(Mavericks) |
| The plugin installed necessary files to Maya 2014 folder.shelf is there i don't get any errors but UVLayout does nothing when in Maya |
Posted: Sat Aug 16, 2014 12:21 am Post subject: |
Type this into the Maya command/script window ...
uvlayout_open;
... and see if the plugin setting window pops up. If it does, try this next ...
uvlayout_run;
.. .which would normally run UVLayout itself.
If those commands work, then it looks like the plugin *is* working, but not the shelf icons. If that's the case, try making your own shelf icons and see if that works any better.
