tikal
Posted: Thu Nov 28, 2013 3:36 am Post subject: menu tricks to activate pin selection |
hi guyz, i m testing using your software and it look to be very powerfull.
i have just a little issue about the menu logic.
what i need to do is pinning all the marked faces so that i can flatten with shift B only some faces.
well , as far as marking faces, i have no problem, i can move my mouse pointer on the faces pressing g.
but then to pin those faces is a hell.(for me for sure:)))
i succeded only once....prehaps i m tough in learning:)))
the button is p .
i notice that buttons work differently if mouse is on the shell or outside, but, which is exaclty the way i have to follow???
thanks in adavance for my silly quesiton!!!
mat |
Posted: Thu Nov 28, 2013 6:09 pm Post subject: |
So after marking your faces, move the mouse pointer so its away from any shells ... still inside the graphics window, but not over any geometry. Tap the G key to bring up the marking menu, then tap the P key to pin all marked polys. Use G then Shift-P to unpin marked faces.
