Removing Stretching ?
SuperSheep
PostPosted: Tue Nov 12, 2013 7:27 pm    Post subject: Removing Stretching ? Reply with quote
I tried, slicing up the object further then merging the slices. I've also tried the 4+5 hot keys but I can't eliminate the stretching, any suggestions ?
PostPosted: Tue Nov 12, 2013 7:44 pm    Post subject: Reply with quote
The red indicates that those polys are larger on the 3D model than they are when flattened, so if you want to reduce that (and reduce the texture stretching) then you need to allow them to expand out further.
If you remove those straight edge constraints, then that will allow the red center polys to push themselves out. But obviously you have those edges straight for a reason, so that's your trade-off ... if you want straight edges there, you're going to get stretching ... to get rid of the stretch, you're going to have to accept curved edges.
Sorry, there's no magic answer :)
SuperSheep
PostPosted: Wed Nov 13, 2013 11:36 am    Post subject: Reply with quote
Ah, thanks for the help Smile
