i wounder how i do to continue cutting after flatten the uv,
Thewiruz
PostPosted: Wed Jan 23, 2013 10:02 am    Post subject: i wounder how i do to continue cutting after flatten the uv, Reply with quote
Hi
I have a problem. Often when i have cut a uv map i see that i need to cut it more after i have dropped and flatten the uv,s .
When i toggle back via U and start cutting i cant drop the new cut. What am i doing wrong? i see the cuts but will not be affected when i reflatten the uv,s
PostPosted: Wed Jan 23, 2013 3:23 pm    Post subject: Reply with quote
You can stay in the UV view to tag the cut edges with "C", then use Enter on that shell to actually cut open those tagged edges.
Thewiruz
PostPosted: Thu Jan 24, 2013 5:52 am    Post subject: Reply with quote
Ahh thanks!
i was trying to cut in the viewport but that didnt do much Smile
Thanks!
