Paint Polygons Selecting too Fast
SuperSheep
PostPosted: Mon Jan 07, 2013 5:59 am    Post subject: Paint Polygons Selecting too Fast Reply with quote
Can I prevent the paint polygons "G" key from selecting the entire mesh section ? I can't hit the "G" key fast enough otherwise it selects the UV island in 3D Edit mode, is there a way to slow this down so I can be a little more precise ?
PostPosted: Thu Jan 10, 2013 6:33 pm    Post subject: Reply with quote
If you press and hold G it should only select the poly under the mouse pointer, then you move the pointer around to select other polys. Selecting the entire island should only happen if UVLayout gets a double-tap of the G key.
