SuperSheep
Posted: Mon Jan 07, 2013 5:59 am Post subject: Paint Polygons Selecting too Fast |
| Can I prevent the paint polygons "G" key from selecting the entire mesh section ? I can't hit the "G" key fast enough otherwise it selects the UV island in 3D Edit mode, is there a way to slow this down so I can be a little more precise ? |
Posted: Thu Jan 10, 2013 6:33 pm Post subject: |
If you press and hold G it should only select the poly under the mouse pointer, then you move the pointer around to select other polys. Selecting the entire island should only happen if UVLayout gets a double-tap of the G key.
