Deleting a couple of polys.. (solved)
dresdenwitch
PostPosted: Sat Nov 17, 2012 7:00 pm    Post subject: Deleting a couple of polys.. (solved) Reply with quote
is it possible to remove a couple of polys that snuck through the making??
I have cut everything up and while doing so found a couple of bits that although won't be seen in the final obj, I don't need in the count.
I have now put them in the UV room with the rest, but is there a way to delete them rather than going back out and deleting them in my modeling program?
Just being lazy here. Laughing
GeoffRiley
PostPosted: Sun Nov 18, 2012 5:09 am    Post subject: Reply with quote
It depends on the modelling program - technically it should be simple, delete the polys and delete the associate texture vertices, especially since those appear to be disjointed anyway.
However, some programs just throw away the who UV map if you make a change to the vertex table - that is if you add or delete a poly.
My advise is to backup and then try it. I cannot remember which, if any, of the freebies leave the UVs in tact, but if your modeller doesn't do it, it may be worth trying the same thing in Blender, Wings3D, etc.
Otherwise... it is possible to do it by hand, but it's a long job and not for the feint of heart! Shocked
Geoff
dresdenwitch
PostPosted: Sun Nov 18, 2012 12:04 pm    Post subject: Reply with quote
I went back and took them out with the modeling program I use.. Laughing
PostPosted: Sun Nov 18, 2012 5:29 pm    Post subject: Reply with quote
"is it possible to remove a couple of polys"
No sorry, there's no geometry editing in UVLayout. One of the reasons for that is so that the modified UVs can be easily merged back into the original OBJ file.
dresdenwitch
PostPosted: Mon Nov 19, 2012 10:30 am    Post subject: Reply with quote
I sort of thought that.. as I said.. I was just seeing if there was a lazy way ... LOL sometimes there just isn't any shortcuts. Rolling Eyes
GeoffRiley
PostPosted: Tue Nov 20, 2012 5:16 am    Post subject: Reply with quote
Doh! Sorry, I completely missed that you were asking if it was possible within UVLayout... I must have been having a particularly dense day. Embarassed
PostPosted: Tue Nov 20, 2012 5:29 pm    Post subject: Reply with quote
That happens to us all :)
But back to the original question, in my own special dev version of UVLayout I do have the ability to save out only part of the mesh. I haven't included it in the release because it breaks the "no modifications to geometry" rule, but maybe it would be a handy option for you all to have. I'll see if I can get it into the next release.
GeoffRiley
PostPosted: Wed Nov 21, 2012 6:45 am    Post subject: Reply with quote
Once in a while it can possibly be useful - but we don't want too many 'useful little extras' like that coming in really... UVLayout does a truly magnificent job at what it was designed to do and that needs to be the focus of it: I've seen too many good packages ruined by 'good-idea-itus' over the years where the main thrust of a program has been lost under a deluge of feature creep.
We don't want to end up with an all singing all dancing vector editor that just happens to do a wonderful job at UVLayout.
If you see what I mean. Rolling Eyes
dresdenwitch
PostPosted: Wed Nov 21, 2012 11:15 am    Post subject: Reply with quote
and we don't want you to break any 'rules' either. I don't think it's a big deal.. one just has to look better when making the object. Laughing
PostPosted: Thu Nov 22, 2012 1:04 am    Post subject: Reply with quote
Thanks both for the input! I'm also cautious about feature creep, but might do it anyway. The option to only save out polys that have UVs is a logical feature for a UV editor to have I think, I just have to be careful it can't be selected accidentally.
