jinjin
Posted: Wed Sep 19, 2012 11:51 am Post subject: Linux installation issue, please help. |
Hi there,
I have UVLayout 2.08 installation problem on Linux (Centos 64bit).
By following your instruction (http://www.uvlayout.com/index.php?option=com_wrapper&Itemid=110), I successfully passed these two commands:
export HEADUS_HOME=/usr/local/uvlayout-demo
export PATH=$HEADUS_HOME/bin:$PATH
Then when I tried to use the following command:
mkdir -p $HEADUS_HOME
It shows: mkdir: missing operand
Could you let me know what is happening at this step? |
Posted: Wed Sep 19, 2012 6:44 pm Post subject: |
The error would imply that the "export" command isn't working, because the $HEADUS_HOME variable has nothing in it. You have to run all of those commands in the same shell window.
jinjin
Posted: Thu Sep 20, 2012 9:02 am Post subject: |
headus wrote: | The error would imply that the "export" command isn't working, because the $HEADUS_HOME variable has nothing in it. You have to run all of those commands in the same shell window.
Thanks for your reply, Phil.
I have successfully passed those three commands (typed in one shell). The demo version had been installed into usr/local/uvlayout-demo. There are five folders inside usr/local/uvlayout-demo.
After that, I typed UVLayout into a new shell window and tried to run it but the shell shows: Command not found.
I also tried to type unlayout as well as headus in the shell which those three commands passed)
Here is a screen snap (see attached image)
Could you help me on this again ?
Many thanks, |
Posted: Thu Sep 20, 2012 5:36 pm Post subject: |
For libXm, read this ...
http://www.uvlayout.com/openmotif/
For libgomp, you'll need to use the package manager on your system to install that. There may be other missing libraries though, but you'll find that out once libgomp is installed and you try and run uvlayout again.
You may want to use a wrapper script too to run uvlayout. Info on that can be found here ...
http://www.uvlayout.com/doc/Installation_Guide:_Linux
Getting UVLayout to work on Linux is more complicated because there's lots of different distos, and which libraries are loaded by default can vary. If you just want to see how UVLayout works, using the Win or Mac Demo version would be easier, and then you can tackle the Linux installation if you want to take it any further.
jinjin
Posted: Fri Sep 21, 2012 8:59 am Post subject: |
headus wrote: | For libXm, read this ...
<<Links blocked until user has been cleared>>
I went to the page you recommended to me for installing libXm (I installed it by typing export LD_LIBRARY_PATH=$HEADUS_HOME/lib). But I still can't figure out the libgomp file. I checked add/remove Software in Centos, it shows GCC OpenMP3.0 shared support library - libgomp-4.4.6-4.el6 (x84_64) ticked already (I assume it has been installed by Centos already).
After that I tried to type uvlayout in a shell, it still shows
Thanks again, |
jinjin
Posted: Fri Sep 21, 2012 9:52 am Post subject: |
jinjin wrote: | headus wrote: | For libXm, read this ...
I went to the page you recommended to me for installing libXm (I installed it by typing export LD_LIBRARY_PATH=$HEADUS_HOME/lib). After that I also install libgomp.so.1 file, libXm.so.4 file, LibGLw.so.1, libXpm.so.4, libtiff.so.3.
Now I ended up with this in shell:
uvlayout (Enter - after entering, nothing happens)
Segmentation fault
I feel it is just one step to get there. Could you please help me again.
Thanks again, |
GeoffRiley
Posted: Sat Sep 22, 2012 7:31 am Post subject: |
Check the permissions of the files in $HEADUS_HOME/bin - make sure that they're readable as well as executable:
Code: | chmod 755 $HEADUS_HOME/bin/* |
may help to sort this out - it shouldn't really be necessary, but it helped my setup.
Geoff |
jinjin
Posted: Sat Sep 22, 2012 12:40 pm Post subject: |
GeoffRiley wrote: | Check the permissions of the files in $HEADUS_HOME/bin - make sure that they're readable as well as executable:
Geoff |
Thank you for your kindly help.
I figured it out. Now, it works on Linux. However, when I type uvlayout in terminal that opens uvlayout flawlessly but terminal then shows this (please see attached image).
If someone could teach me how to install those missing fonts so I can make uvlayout working perfectly on Centos 64. |
jinjin
Posted: Sat Sep 22, 2012 11:29 pm Post subject: |
Posted: Sun Sep 23, 2012 6:19 pm Post subject: |
On some distos those fonts are in the "xfonts-75dpi" package. I just did a google search for centos and it came up with the "xorg-x11-fonts-75dpi" package, so maybe try that too.
GeoffRiley
Posted: Mon Sep 24, 2012 10:23 am Post subject: |
Sorry I didn't get back - got a bit busy over the weekend.
Yes, the different distros seem to shuffle the fonts all over the place{1}; I've found that the substituted fonts work quite adequately though, so, although the warnings list in the terminal window, there is no problem with the actual running of UVLayout.
Geoff
{1} Worse still - different versions of one distro seem to move the fonts between packages.  |
jinjin
Posted: Mon Sep 24, 2012 11:46 am Post subject: |
GeoffRiley wrote: | Sorry I didn't get back - got a bit busy over the weekend.
Geoff
I solved the fonts issue. Now, uvlayout run nicely on Centos 64. I tried to load a completed ploygon model into the uvlayout, it seems working very well until I change the view windows size it disappears until I finish the changes of window size and release my mouse. The loaded model then shows up again.
Also when I click different section buttons (for instance,Edit, Optimize and so on) after using them and close the option windows by click "X" button on the upper right corner, the loaded mesh quickly disappears and then shows up again. I know it doesn't matter with the using of uvlayout. I just want to report this little problem and want to see if other people have the same problem. If so, I guess it is a uvlayout Linux version issue. |
Posted: Mon Sep 24, 2012 6:33 pm Post subject: |
"so, although the warnings list in the terminal window, there is no problem with the actual running of UVLayout."
Thanks for the tips Geoff! Actually, because its X11, you can configure UVLayout to use whatever fonts you want via a .Xdefaults file. You need to add something like the following ...
Code: | UVLayout*fontList: \
-b&h-luxi sans-bold-r-normal-*-12-120-75-75-p-0-adobe-*=avant_120,\
-*-helvetica-bold-r-normal-*-*-140-*=avant_140,\
-*-helvetica-bold-r-normal-*-*-180-*=avant_180,\
-*-helvetica-bold-r-normal-*-*-240-*=avant_240,\
-*-helvetica-bold-r-normal-*-*-100-*=avant_100,\
-*-helvetica-bold-r-normal-*-*-80-*=avant_80,\
-adobe-courier-medium-r-*-*-*-120-*-*-*-*-*-*=courier_120,\
-adobe-courier-medium-r-*-*-*-100-*-*-*-*-*-*=courier_100,\
-adobe-courier-medium-r-*-*-*-120-*-*-*-*-*-*=console_120,\
-*-symbol-*-*-*-*-*-120-*=symbol_120,\
-*-symbol-*-*-*-*-*-120-*=symbol_180
The name after the "=" on each line (e.g. "avant_140") is what UVLayout uses internally when specifying a font for a particular button or label or whatever, so dont change any of those. But you can substitute your own font definition before the equals. I personally use "xfontsel" to work those out. so if you find that the default UVLayout fonts are too big or too small for you, you can tweak them this way.
Posted: Mon Sep 24, 2012 6:43 pm Post subject: |
"I solved the fonts issue. Now, uvlayout run nicely on Centos 64."
Thanks for the good news!
"until I change the view windows size it disappears until I finish the changes of window size and release my mouse. The loaded model then shows up again. "
Yes, that's on purpose. On slower or older systems, disabling the mesh draw helps to make the window resizing a lot smoother. Especially on systems without a dedicated graphics card, doing both at once (resizing and redrawing) was too jerky.
"Also when I click different section buttons (for instance,Edit, Optimize and so on) after using them and close the option windows by click "X" button on the upper right corner, the loaded mesh quickly disappears and then shows up again. "
The mesh is supposed to disappear when you move the floating panel around (i.e. left mouse drag blue title bar) for the same reason as above. I've never noticed the mesh flicking off though with the panel close, but just checked and it is doing it here too. I expect its getting an X event there briefly that makes UVLayout think the the panel is about to move. The mesh blanking only happens though if you have the floating panel overlapping the 3D window ... I personally position my floating panels off to the side so they dont overlap.
jinjin
Posted: Mon Sep 24, 2012 10:58 pm Post subject: |
headus wrote: | "I solved the fonts issue. Now, uvlayout run nicely on Centos 64."
Thanks, Phil.
Understood.
It seems windows version hasn't got the same flickering concept (Can't really remember if it has, I tried windows version before, it seemed running very smooth without any flickering appeared when moved or resized the 3D viewer window and additional property windows).
Anyway, I'm happy to try this software on Linux, it's indeed one of best UV unwrapping tools so far.
Cheers, |
