bonga
Posted: Wed Aug 15, 2012 8:45 am Post subject: SEEING UV |
After i cut and drop the shell and edit it, i'm having trouble viewing some parts of it.
I have a character with a cape and i see alot of red on his back, but the cape is in the way. How can i move the cape to better view the model. This is in the mode where you use "T" to toggle between numbers and squares.
Thanks, you're always a great help. |
Posted: Wed Aug 15, 2012 5:28 pm Post subject: |
The "H" hotkey is the one you want to use ... it accesses a menu in the display window for hiding bits of the mesh in various ways. If the body is a separate UV shell to the cape, then the simplest thing to do is to switch to the UV view, type H and H again with the mouse pointer over the body shell, and that will hide everything except that UV shell. Then switch back to the 3D view to see just that shell.
