Error message "Problems loading/no such file or directo
tedg
PostPosted: Tue Jul 10, 2012 1:59 pm    Post subject: Error message "Problems loading/no such file or directo Reply with quote
I haven't used Headus for awhile, but when loading a previously saved and opened .obj file, I get the error "Problems loading/no such file or directory". I'm on a Mac, and have the .obj on my desktop, and it's also visible in the UV Layout Load menu. It's a directory problem, but I'm overlooking something- please see screener and offer advice, thank you! Laughing
PostPosted: Tue Jul 10, 2012 5:41 pm    Post subject: Reply with quote
Try this ... click the "About UVLayout" button and then "Run Licensing GUI". Down the bottom of that window will be a "Common Preferences" button, so click that and check the "Temp Dir" field. It might be that you set that to something in the past which doesn't exist anymore. You can set a new temp dir (for the OBJ file import/export conversions) by clicking the arrow.
Also check your email for further instructions if the above doesn't help.
